Jonnyb
Can someone clarify something for me WRT the installation on the F-8117 guide bracket.
OP-5 has an MS21051-L08 nut plate installed in the F-804A2 centre section (section 6F of OP5)
However the drilled holes in F-802 which we use as a drill guide match a K1000-8 nutplate as seen in OP-5A which is for the RV-8A. And not the MS21051 as called out in OP-5. What concerns my is that the different nut pat changes the location of the #19 hole, so it’s not something I can undo easily if it’s wrong.
Have people used a K1000-8 nut plate here and OP-5 just hasn’t been updated, or is there something else wrong?
Have asked Vans but I think they might be a bit busy!
The pic on the left is OP-5A on the right is OP-5.
