I started to put together the rear seat rudder kit today. Tried to hand fit some if it together. Immediately ran into two issues.
First is that the AN490-HT6P rod end will not fit into the tube. Given how thin the tube is, I'm not going to ream it out. I could pound it in there, but I try to avoid pounding things as a rule.
Second is that the rod end and the female Heim type bearing won't screw together. I double checked the thread sizes with a gauge and even checked the handedness. Again, I can get out the BFH to make it fit but really don't want to force it or ruin the parts.
Has anyone run into anything like this before?
