Rear Mount Governor
Mitch757
Sponsor
I'm interested in the PCU-5000X group buy and one of the questions on the spec sheet is for "Control Lever Angle"
For those of you with a rear governor on a 7 or 9, could you tell me what I should put on the spec sheet?
Any photos of the rear of the engine?
Thanks a bunch,
Mitch Garner
RV9A...coming along
Thanks a bunch,
Mitch Garner
RV9A...coming along
I put 290 on mine but it sounds like basically everyone has to change the angle when installing it. It is easy to change.
I just asked the same questions for the RV-10. What I heard back was everyone needs to adjust a little and it's easy to do.
Make sure you get the rotation direction correct -- actually not sure it makes as much difference with a rear-mounted unit.
I don't know if you guys have emailed Brent yet on getting the forms going but there is FAQ document he sends that helps a bit too. As far as rotation goes here is what is on the form.
Control Lever Rotation. Do I need Clockwise or Counter-Clockwise?
Depends on where your control cable attaches to the lever. The lever rests against the high RPM/low pitch stop,
therefore when trying to determine this, imagine how the lever would rotate as your pull the prop control out,
toward a lower RPM. Whatever the answer is (clockwise or counter-clockwise) is what you would put on the form.
