Just want to get some input from other RV10 owners on how they find the rear cabin heat working. I now have 120hrs on the Rv10 since this march and have been coast to coast. Had a chance to fly in temp from -20C to +35C. The problem I am noticing is the passengers in the back start to get cold if the temp get around the freezing mark or less. I understand after a certain tempurature there is nothing you can do to keep warm. High flights in mid summer can make the location uncomfortable. I crank the heat which is plenty hot coming out the back but that just means they get sweaty feet
and the rest of them does not stay warm. My but gets pretty hot too as it is blasting in the general area. I very seldom ever turn the front heat on. One item that I am just finishing is closing of the rear bulk head with insulation as there is a large draft that comes from the tailcone. I am guessing that it comes though the bent stiffners of the baggage bulhead closure. That should help some but I think the best help would be to deflect the heat with a small elbow more towards the rear passengers to help warm them up. There is not much room there to do that but I have a couple of ideas.
Any thoughts out there??
