Need Advice
There is a drawing conflict between Drawing 31 section AA where the battery cable runs through the spar web. on this drawing it shows it above the aileron push rod yet on drawing OP11 Wiring Harness Instalation it shows the battery cable penetration below the push rod. It also looks like this lower hole could interfere with the aileron push rod.
Where have previous builders penetrated the spar web for the battery cable.
A picture would be great.
Rob
A very very slow build RV8
Rob
