Rear battery cable length
rv8or
RV8 battery cable lengths.
What are the following 2AWG cable lengths in an RV8 with rear battery.
Rear master solenoid to firewall starter solenoid.
Starter solenoid to starter
Battery to master solenoid.
I’m away from home and need to measurements to get the cables made.
Thanks in anticipation.
Rob
Tough to say. Depending on cable routing, master bus termination, etc. - each installation will have unique lengths. Best wait till you can make measurements for your specific plane.
Cable lengths
Ralph
There is a length using the standard cable routing which is what I’m doing. Something like 138 inches but I cannot remember exactly.
Regards
Rob
OK, found on OP-10 drawing dated 1/12/99 - cable from master relay to starter relay is 126". No lengths listed for the shorter length cables.
You might check on the on-line plans if there is a later drawing for this.
