First, Happy New Year to everyone and I wish you all an awesome 2017.
So Im ready to paint the inside cabin top and door interiors. I have done the micro and finished with an epoxy wipe. It looks good for painting, so is this the correct process. Spray with a couple coats of high fill primer. Let it flash, spray two coats of color, let flash. Spray with two coat of clear coat. My question,
Do I need to sand the high fill or can I go to the color coat without sanding once the primer flashes off. Am I missing any process.
For the interior aluminum, I plan to use self etching primer, then color, then clear.
