I'm now in the process of swapping out my AmeriKing 450 for a new ACK E04 ELT. The long telephone cable that runs from the ELT to the Remote panel appears to be an identical wire from both manufactures.
I'm going to test the existing cable with the new ACK ELT and if it functions properly, is there any reason why I can't use the existing wire that is installed in the plane?
My RV4 appears to have been built around the cable and to change out the cable is a major PIA. The Antenna I will change as that is not an option.
Tim
Tim
