I've been priming all my parts with AKZO.. however on the tailcone I'm going to top coat it with some Rust-Oleum Professional High Performance Enamel Spry Paint (Light Machine Gray) rattle can. Why? Cause it's pretty, will be visible and I'm envisioning easy touch up down the road.
I just primed a mess of pieces this afternoon and want to make sure this doesn't end up looking shotty. It's my understanding you should top coat AKZO within 3-24 hours... or if you wait longer then you need to sand it for proper adhesion.
Since I'll rattle can everything tomorrow is there any tips or tricks to ensuring it looks goodish? Should I just go nuts with the cans or should I hit it with some high grit sandpaper, maybe wet sand wipe clean and then spray?
Thanks!
Thanks!
