Pilottonny
Hello everybody,
Since I did not get an answer on my question in my last thread, I started a new one, with a new title.
I hope someone can help me with the following numbers, that I require to supply to the Silencer Manufacturer "Liese" in Germany, so he can calculate whether he can supply me some mufflers to satisfy the very stringent European noise regulations.
Can anybody give me the "Max Rate of Climb @ what airspeed" for an RV9A equipped with an IO-320 with CS-Prop (at solo weight and MTOW, if possible).
Also I need to know the take-off over 50 ft obstacle (at solo and MTOW, if possible). If you do not know that, just give me the ground roll and I will calculate it with the max rate of climb and the airspeed. That should then be close enough.
Thanks in advance for your help.
Regards, PilotTonny.
