RudiGreyling
Hi Guys,
posting in RV7 section, since no specific section for plumbing.
This is my first time working with Pitot, Static and AoA plumbing lines, so I want to check what you guys think...
I bought the Safe1air kits, with quick connects. Heated some of the bends with a heatgun for them to keep the desired bend and put no tension on the rest of the lines. I have a tipup canopy so the 3 lines will come in straight through the sub-panel with grommets directly into the Dynon in the 3 top positions, and then they are distributed to the rest of my instruments as showed. Luckily all my instruments that require plumbing are close together.
Questions:
1) Since it is my first time, does it look functional? Any improvements?
2) How good are the Safe1air quick connects? Any problems, advice?
Thanks in advance
Regards
Rudi
The Pictures
Questions:
Thanks in advance
Regards
Rudi
The Pictures
![plumbing_1.jpg](/proxy.php?image=http%3A%2F%2Fwww.rudigreyling.com%2Fpictures%2Frv_forum%2Fplumbing_1.jpg&hash=e726ab537d457fe420b8254392a22df3)
![plumbing_2.jpg](/proxy.php?image=http%3A%2F%2Fwww.rudigreyling.com%2Fpictures%2Frv_forum%2Fplumbing_2.jpg&hash=6f63070f1a4a2bcc348c8d8597eb33ca)
