IowaRV9Dreamer
I'm planning on mounting the Rami bent whip COM antenna on the forward floor, just in front of the spar and just under the gear mount.
The floor skin in 0.040 (pretty thick) and I can mount it such that 2 of its 4 screws will pass through the floor stiffener, which would be a very solid mount. If I do that, I can't use the "backing plate" that it comes with, since the stiffener will be in the way.
Has anyone else done it this way?
