Gash
I will be installing a Garmin GTN-650 in a 14vdc system soon. I am unsure if I should go with the standard 10 watt transmitter, or if I should wire in a 14-28vdc voltage converter so that I can use the GTN-650's 16 watt transmitter option.
Why would I want 16 watts of radio transmit power? What are the practical operational reasons for going with 16 watts instead of 10 watts? Thanks very much.
