Radio rack problem p42-09
jamescone
When you mount your radio rack for the SL-40, if you follow the instructions on page 42-09, you will have to remove the rack when you get to step 4. That step says to attach the antenna to the rear of the rack. You can't do that without removing the rack. There is not enough room between the rear of the rack and the firewall. You shoud do step 4 before step 2.
