N546RV
So there I was, working on my rudder. Time to flute the forward flange of the tip rib to fit the counterweight skin. No big deal, right? Of course!
So I do a preliminary look, holding the skin over the flange. Ok, don't need to move it much...I get out the fluting pliers, put a little flute in, compare to the skin...ok, needs more...I squeeze the pliers a little harder. Check the fit...still not quite there. Squeeze the pliers again, and as I remove them, I can immediately see that I squeezed too hard. As in my flute is now a very pronounced V shape and has a nice little crack.
So here's my question: Is there any reason I can't modify this flange and make it into two pieces? Assume that proper edge distance is maintained and I ensure that the base of the "split" is properly radiused to relieve stress. This would, of course, also have the side benefit of making it a lot easier to get those holes to line up.
Illustration of what I have in mind:
![9u5je9.jpg](/proxy.php?image=http%3A%2F%2Fi45.tinypic.com%2F9u5je9.jpg&hash=ec8807396891976b722ca4a438fbbcab)
