dhmoose
I recently began the QB fuselage assembly (or should I say, disassembly as my first steps were to unscrew all the panels!!). Upon verifying the assembly, I reached section 25-7, Step 3. Here are some pics from the instructions:
I then verified the instructions against what was actually built, but noted 470 rivets were used (and nothing was countersunk) instead of the called for 426 rivets:
This is seen on both the left and right sides and doesn't look accidental, but then again, doesn't follow the plans. Did the guys in the Philippines make a mistake? Is this common? I'll go ahead and replace these but I guess I'll keep a close eye on the rest of the plans/build.
David
![FP10042011A00047.jpg](/proxy.php?image=http%3A%2F%2Fwww.kitlog.com%2Fphotos%2Fproject_796%2Ffull%2FFP10042011A00047.jpg&hash=afa3bd1c2be1e795baf6472cd007ab0f)
![FP10042011A00048.jpg](/proxy.php?image=http%3A%2F%2Fwww.kitlog.com%2Fphotos%2Fproject_796%2Ffull%2FFP10042011A00048.jpg&hash=857c617410382714bc9fc8acc24c828d)
![FP10042011A00049.jpg](/proxy.php?image=http%3A%2F%2Fwww.kitlog.com%2Fphotos%2Fproject_796%2Ffull%2FFP10042011A00049.jpg&hash=cf90b1f5a4d8e80ac1028a76b65577e8)
![FP10042011A0004A.jpg](/proxy.php?image=http%3A%2F%2Fwww.kitlog.com%2Fphotos%2Fproject_796%2Ffull%2FFP10042011A0004A.jpg&hash=778ffaef2eca5db66f1aceb427d345f5)
David
