JackinMichigan
Hello,
Can't seem to figure out how to post photos, so please bear with me.
My father and I got our RV-10 as a quickbuild, which means the forward half of the fuselage was, in essence, complete. It came with an iron bar going the complete width of the fuselage for the foot peg mounts, and we both simply assumed this was a permanent part of the airplane. Today, as we were trying to fit the elevator push rods, we found that this bar made this installation impossible. After reviewing the fuselage build instructions (in a chapter we never looked at, as it was included in the quickbuild) we found that this bar is NOT part of the airplane, and must be removed and replaced with the provided foot peg weldments that end just short of the center tunnel. The bar isn't mentioned anywhere, in fact.
The problem is this: in order to install these foot pegs we will have to match drill and thru-bolt them into the mounting sleeves, which are located under the baggage area floor pans. These floor pans have already been completely riveted in (and have for some time). I count about 250 rivets that will need to be drilled out to remove these floor pans
If there was a warning in the instructions cautioning quickbuilders about this pitfall I must have missed it. I can't be the only one that's run into this. Do I seriously need to drill out all these rivets
Thank you,
Dave
Thank you,
Dave
