RudiGreyling
Hi Guys,
It?s Sunday, I?m stuck and no Vans to contact, and want to continue to build, so I want to post this quick query:
The plans say the Tank Attachment Angle (T-405) should be 2? long, and you should contour it to fit into the nose rib. Problem if you make it 2? long and contour it as per plans, when you fit it in the rib there is no clearance for the nose rivets (position shown in red)
I checked my preview plans, but I can?t figure out how this attaches to the fuse. I wanted to see if the 2? is a critical measurement, or if the bracket on the fuse is adjustable to compensate for more.
I hope someone that has gone through this and fitted the tanks to the fuse already, can help.
The way I see it one has one of 2 choices.
1) Leave the tank attachment angle 2? long, but move it back to create the clearance for the rivets. (This means it will be more than 2? from the front of the nose +/- 2 ??, and it means the fuse bracket needs to be ?adjustable? to compensate); OR
2) Remove more of the sides of the contour and the front of the tank attachment angle so that the rivets can clear, making the attachment angle shorter +/- 1 ?? but keep the 2? measurement from the front of the rib.
What did you guys do and how did it work out?
Thanks in advance,
Kind Regards,
Rudi
![tank_aa_02.jpg](/proxy.php?image=http%3A%2F%2Fwww.freepgs.com%2Fflyboy%2Fpictures%2Frv_forum%2Ftank_aa_02.jpg&hash=f9f7f71dbfa8c613103bfc0d9f160c30)
![tank_aa_01.jpg](/proxy.php?image=http%3A%2F%2Fwww.freepgs.com%2Fflyboy%2Fpictures%2Frv_forum%2Ftank_aa_01.jpg&hash=6f35d92233becd1a6f8ab723d3ac6dec)
Thanks in advance,
Kind Regards,
Rudi
