rjcthree
Hi, I'm at work, drilling out the brass aileron bellcrank bushings - and somehow I split one, longitudinal cracks - as in plural. I would not have thought that was possible, seeing as I had chucked it up in a collet, was using a light lube, and only drilling out to F at 2000 rpm, but it's cracked. First one was perfect. I can only suspect the material at this point.
Clarification: Under 10x power, I count no less than 8 longitudinal cracks in the material visible on the outside of the tube. I'd love to say I did something dumb, but the machinist and the metaurgist say no. Something isn't right with the mat'l.
I put in an order late yesterday with Van's for some other stuff(bent pushrod, grrr), and I'm hoping to catch that order before it goes - but I need the brass bushing part number - and any take a quick look for me? I think it's on 15, but it's somewhere between 11 and 16 (duh!).
Thanks in advance!
Rick 90432
Thanks in advance!
Rick 90432
