Pat Stewart
Looking to upgrade a 7A panel with a Dynon Quick panel. The aircraft has a slider canopy. The control module shows the fuse block in the module, how does one gain access to the module to change a fuse if it is mounted between the panel and firewall. It seems like the RV12 module would be a better solution for a slider which puts the fuses in the panel.
