WingnutWick
Hello,
I am changing an RV-6A over to push button starting which I did with my 8 with success and I love it. Looking at this 6's switch on the back there are a couple things I am not sure what they are for however. First is a jumper that looks like it has a diode in it connecting the + to the ground. What is this for? Is it needed? At the moment I just took the + and the starter and connected them to the push start button.
Finally, in the photo, off the mag wire there are two other white wires coming out. They aren't labeled and I can't get a good trace on where they go without completely undoing everything. Any ideas what these could be?
This is an H2AD O-320 with one of those dual siamese - type mags. Only one side is being used as it has an electronic ignition as well.
Thank you for the help!
![IGNIT-01.jpg](/proxy.php?image=https%3A%2F%2Fi.ibb.co%2FstMRdBb%2FIGNIT-01.jpg&hash=fcfa1cf49adaae44572e157c703c93a8)
