mikeangiulo
Active Member
I'm looking at drawing 73 and trying to mark the three locaitons for the bolts that attach the bottom of the VS rear spar. The bottom middle bolt seems to be aligned 1/32 higher than the line connecting the two rivets in the aft bulkhead. That's fine. But when I go to measure up for the two bolts that go through the lower hinge bracket I can't figure out the measurments. The plans say "7/8 2pl" but that wouldn't be far enough. The plans say they are 50% scale and the measurment isn't even 7/16" so that has to be a typo.
Then it says double check for edge distance. So should I start with an estimate of 2D for the bolts (which would be 1/2") up from the bottom edge of the hinge bracket? it's hard to tell where that's going to come out the other side.
If anyone has the plans handy and wants to help me understand how I'm reading those dimensions wrong I'd sure appreciate it!
Oh and may your favorite team win today.
