OK folks, before all the OWT's come out of the closet let me state some FACTS you can take to the bank.
1. You can run a carby engine LOP, just most do not have a good balance of fuel air mix to each cylinder to get them all LOP without the first one starting to stop producing power and hence rough running.
I recently had the pleasure of flying in an RV6 with O-360 and CSU and we could run it at 8000' with WOT and about 2350RPM, and just get the last cylinder around peak or a couple LOP and the first one was about 25-30 LOP, it was barely noticable in roughness, just as it should be.
Some carby engines will run LOP more successfully with carb heat or the throttle cracked enough that you see a small MP drop, the turbulent air from the butterfly stirs things up enough you get a better mix, but its all trial and error.
2.
you would lean based on the last to peak and it may not necessarily be 50 degrees LOP.
This is true, low altitude you will get a higher number LOP to get away from the potential detonation zone. At 7000' or higher which is generally around 23"MP you can run safely just LOP or say 0-20 LOP, if you start going further the power drops away rapidly.
3. Articles #63 - #66......PRINT THESE OFF and read them through about 7 or 8 times. Yes I am serious, maybe more, you need to understand this stuff, not just have read it once.
4. You guys are lucky over there, its easy for you to do the APS courses. The cost of the course will be paid back in fuel and engine maintenance costs ina very short time. Unless you understand this stuff really well, and you do not attend I think you are foolish. The best money invested in your aviation life.
http://www.advancedpilot.com/
5. Study these two tables carefully, found in the JD articles.
Red Box = No Fly Zone
? At and below about 60% power, there is no red box. Put the mixture wherever you want it.
? At about 65% power or so, 100?F ROP to Peak.
? At about 70%, 125?F ROP to 25?F LOP.
? At about 75%, 180?F ROP to 40?F LOP.
? At about 80%, 200?F ROP to 60?F LOP.
Outside the Box
? At 65% power, use richer than 100 ROP, or leaner than peak EGT.
? At 70%, use richer than 125?F ROP, or leaner than 25?F LOP.
? At 75%, use richer than 180?F ROP, or leaner than 40?F LOP.
? At 80%, use richer than 200?F ROP, or leaner than 60?F LOP.
I am not George or John or Walter by any stretch...........but if you have questions post or PM or email me. I am happy to educate anyone willing to learn.
Green of Peak....
![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
you guys crack me up
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
