I am relocating my ADAHRS to a place that is easier to maintain. However, the location of the ADAHRS is lower than the location of the static port. The embedded picture below shows the relative location of the ADAHRS and the static port. The static line is tee-off from a location near the top longeron to mitigate any moisture condensation and runs forward to the front panel. The static line is tee again downward toward the ADAHRS, and its location is slightly lower than static port in level flight. When the airplane is sitting tail down, both are located at about the same level.
Question: Is this location acceptable in term of mitigating moisture condensation with the distance between the static port and the ADAHRS is about 36inches? Are there other problems with this setup? Thanks.
