I am in the process of drilling my horizontal stab to the fuselage. With the front drilled and bolted down (including the shims) the instructions say a 3/16" gap below the rear spar and the aft deck will set the incidence at 0. They say to check that with the tooling holes in the inboard stabilizer. With my tooling holes parrallel to the aft deck, my gap between the rear spar and aft deck is more like 9/32" instead of 3/16". I assume it is more important to get the tooling holes parrallel than to worry about the 3/16" measurement.
Am I doing something wrong or is this more the normal way for it to turn out??
