Question on A210 and X96 GPS's
Brantel
Last evening I was testing my A210 in combination with connecting the remote antenna to my 296. When I did connect the GPS antenna, the squelch was opened on the A210 and I got what sounds like about a 100hz buzz.
I can quiet the noise by increasing the squelch setting but is this normal?
The com antenna is on the belly and the GPS antenna was sitting on the top of the panel area.
What squelch setting do you guys with A210's normally run?
