JakeLewis22
I have a question for those who painted the inside of their cowl and/or plenum. What paint did you use and have you seen any heat discoloration?
I'm using a 2 stage (base coat, clear coat) auto paint system on the outside of my RV7 and I was planning to paint the inside of the cowl and plenum with the same paint. I contacted the paint manufacturer and was told that their paint will start to break down at 300 degrees Fahrenheit.
I'm going to install Van's adhesive heat reflector material inside the cowl where ever the exhaust comes close but I want to make sure the paint doesn't break down, especially on the plenum, where I assume it will see temps in excess of 300 degrees but I don't know that for a fact.
Do I need to find a high temp paint or is this a non-issue?
