Hey fastback guys,
We're at the point in the Showplanes plans where we need to start thinking about welding components to the WD-808 seat back weldment. One of those components is the little nut which anchors one end of the canopy gas strut. (Pictured below, with arrow.)
Question: Did you guys drill a hole in the WD-808 behind the welded nut in order to accommodate the full length of the gas strut anchor bolt?
I'd rather not weaken the steel WD-808 if possible, but I guess the only other options would be to cut that bolt a little short, or just leave it sticking out a bit. Any thoughts? What did you guys come up with here?
And while we're on the subject, did you guys try welding everything with the WD-808 installed in the fuse, or just mark and clamp things and then do the welding away from the airplane?
![fastback.jpg](/proxy.php?image=http%3A%2F%2Fmedia.aeropunk.com%2F2014%2F05%2Ffastback.jpg&hash=243a6ead1804d26dd64b156353b77af8)
