Tom Martin
I have seven hours on this new RV10, C-GLWM, it is owned by Wayne and Lana Millson, Port Hope, Ontario. For insurance reasons I am flying the 25 hour test period off for Wayne.
Before today's flight I plugged the bottom of the nose gear faring with foam. My theory is that high pressure air is entering this faring and going up into the cowling. I have sealed, with baffle seal material, around the nose gear faring and the lower cowling. There are no louvers and the cowling extends aft of the firewall three inches or so. We did not trim the cowling. Lots of time has been spent on sealing the upper plenum area and getting the inlets sealed and smooth. I speculate that the air that is entering the cowling from the nose gear faring is not only disrupting the cowling exit area but it is allowing high pressure air into the low pressure area of the lower cowling.
After plugging this faring with foam my oil temperatures dropped 10 degrees.
I would like some other flying RV10s to repeat this experiment and see if they notice any differences in engine temps. Simply jam some foam in the bottom, or top of the nose gear faring, thus sealing this large leak into the lower plenum.
