I have a Dynon 120 EMS and have been experimenting with the Leaning mode, but have a question. I know that once a cylinder peaks, the Dynon will convert the reading from actual EGT to a difference amount from the peak temp. However, I sometimes will go lean then rich again. Sometimes for experimentation and sometimes because I went too lean. Does the Dynon go back to actual EGT once it hits peak and goes ROP or does it stay as a differential reading? It seems that I am seeing some cylinder as ROP and some LOP. However, every number has a - in front of it. If it stays as a differential, how do you know if the indication is LOP or ROP?
I have a carb'ed engine, so I don't have a tight spread.
Larry
Larry
