skyyking56
Please help!!!!
I ran into a couple of cracked #8 dimples in my W-423 joint plate. (I was able to slightly enlarge the ID of the dimple to eliminate the crack). I did a search here and found all kinds of problems with that. The cure seems to be "go to a larger pilot hole".?????? My die fit into the #19 hole without any problem (was NOT tight)
Also in my search on this subject I found problems with pillowing of the LE fuel tank skin so that the LE skin and tank skin are not in surface alignment.
Here is my question: The instructions say to use a C-Frame tool to dimple these holes because "it looks nicer". Does using the squeezer or DRDT-2 causing this pillowing affect????? Is this what they are talking about "looks nicer" (no pillowing problem) ?????
Have any of you out there used a DRDT-2 or pneumatic squeezer and not had this pillowing problem?
Should I borrow a C-frame or buy one just to do these holes so I wont have pillowing in my skins? It seems like an uneccessary process to shim up the LE skin to align with the tank skin if you are following the direction from Vans.
I would appreciate any and many theories on these subjects...
Please help!!!!!!!!!!!!!!![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks again
Jim (7A wings)
Thanks again
Jim (7A wings)
