Lee Jordan
Member
Something appears odd with the countersinking I'm doing for the CS4-4 rivets. I've done the countersinking for the 426 rivets and they all went well, but the CS4 rivet is a pop-rivet with the counter sunk head and I'm wondering if they "fit" differently then the 426?
As I'm machining the hole everything starts out great, but as I approach the correct depth for the pop rivet to sit flush I get a loud screeching from the MCS tool and then I see that the hole in the flange is starting to become enlarged. And I still need to go deeper because the CS4 Rivet is not sitting flush.
About the time I get the rivet to sit flush, the hole "appears" too big because I can move the rivet around.
I'm using the #30 CS bit for these #30 holes. Is that the correct tool?
Lee
Lee
