Scott DellAngelo
My question is about the bottom "pushrod" (not sure what to call it) that is bolted across to tie the two stick positions together. I set the length per the drawing and when I do that, the sticks are slanted in towards each other a little. Is this okay that they are no longer parallel when I do that? Just want to make sure because I am installing the wings tomorrow (weather permitting) and would rather get the push-pull tubes to the ailerons set and then hopefully not mess with them again.
Scott
#90598 Fuselage
Scott
#90598 Fuselage
