tdragger1966
Member
Recently purchased a nearly complete RV-10 tail kit and started work on Section 11. Started with bolting the h-stab to the work bench, setting rod end bearings and attaching the elevators. Both elevator tips interfered with the outboard ribs/skin of the h-stab. Prior builder never got this far so likely never noticed. After much head scratching and inspection it appears they are not straight but progressively "toe in" towards the stab (see attachments). Tried adjusting the rod end bearings but didn't provide enough relief. Asked Van's but they seemed perplexed. Have an EAA Tech Counselor coming this weekend but wanted to get some more opinions.
There's not enough edge distance to simply trim the elevators so I *think* the best solution is to drill out all the rivets in the counterweight skins, try to straighten the ribs while still riveted to the rest of the elevator and attach a new skin (assuming the holes will no longer align). How would you folks address this?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
