My next step is to attach fuselage to empennage. For time management I plan to order the QB Wings August. Compared to the slow build fuselage how long do the QB Wings take to complete. Is the lower skin open and dimpled?
More like 40 hours each. One panel open, needs deburr and dimple. Flap hinge, aileron hinges and wingtip install. Aileron bellcrank installation also. Easy peesy.
I spent 270 hours on the wings (normal build). I don't consider myself a speedy builder, since most of the tasks, I performed slower than the averages. I also took my time while building. I decided from the start it wasn't a race to beat the vans published building time. If you want a sampling of times, look at all the RV-10 build sites on mykitlog.com. All the times are listed if the builder filled out the forms accurately.
The wings are pretty straight forward and simple. The tanks scare a lot of people, but they really aren't that bad. The problem with the wings is that there is quite a bit of repetition that gets old really quick. It's not like the other parts of the aircraft where you are doing a different task on every page of the plans.
