The ailerons are mounted and now I'm fitting the flaps. Problem is that the piano hinge that comes attached to the flap is about 1/8" too short. If I set up the flaps with the 1/4" gap between the flap and aileron as shown on the plans then the piano hinge doesn't reach the prepunched hole in the skin at the root end (the end nearest the fuse). Is there something I am missing here? I'm thinking I'll just cut off the long end and add a rivet at the other end.
[/IMG]
[/IMG]
