Is it acceptable for Pitot/ AOA tubing to share the same grommet hole with wiring thru the wing? Planning to enlarge the holes already in the ribs to 3/4 inch and use SB750-10 bushings. Want to make sure I have enough grommet clearance in the left wing to run 1 aoa or pitot line tubing, wiring for GAP-26, and required wiring for the Zip Tips. Right wing will have GSA-28 roll servo and wiring forZip Tips as well. The GAP-26 came with spade connectors already installed. are these OK or do most people replace with a single molex connector? And does anyone know where to get a decent pair of cleco pliers that the cleco doesn't always end up wedged in the piers crooked.....thanks!
