RVG8tor
I am trying to find out if other had this issue. I was starting my fuel and brake line and thought I should check the torque on the gear weld mounts first since the line will be in the way. I decided to review the instructions for the weld mount installation, since I did not do this I wanted to make sure things on the QB were done IAW the plans. The part in the plans were it tells you to be patient but to keep trial fitting the weld mount and trimming the holes common to the wing bolts to make sure they have at least 1/32 clearance, well it seems this was not done. There are two bolts that hold in the false spar but that is it. I took the false spar out so I could check all the holes and most will not allow a bolt or long punch like I have to make it through. Most get to the weld mount and stop, on is interfering on the aft side of the 804 bulkhead plate. Looking at the weld mount, I can see powder coating still around the inside edges of the holes so no trimming has been done
Did anyone else have this issue (RV8A QB) and what did you do? My thinking is to just take the weld mount out and do the proper fitting. It would have been nice to know I was going to have to take the weld mounts out about 3 weeks ago; I painted then and painstakingly taped up the weld mounts. Painting sure would have been easier without the weld mounts in the way.
Thank you for any help or advice.
Cheers
Cheers
