Hi All-
I received my -14A QB fuselage and am at the point where the plans recommend to paint the cockpit if desired. My goal is to end up with a nice color of EkoCrylic over the top of SEM primer (applied with HVLP) in the aft fuselage and over the top of the SW P060G2 in the factory completed forward fuselage.
My question is related to the forward fuselage. When I clean the surface with isopropyl alcohol, I get a lot of ?green? on my rag. Is that normal? Should I be wiping/cleaning until I get a clean rag before moving on?
My second question is related to the top coat. Once prepped, any issues applying the EkoCrylic directly on top of the P060G2 primer surface in the forward areas?
Lastly, what do I NOT want to paint in the cockpit? What areas need to be masked off?
Thanks much.
Thanks much.
