I have quick built wings and I'm near the point of closing the lower skin. As this is a quick built I don't have access needed to make additional holes for running conduit as others have.
I built a house a number of years back. I could't see into the future. As a result, I didn't install the numerous open conduits that could make installing all the new and improved electrical toys easier. Don't want to make the same error with my 9. I have a copy of From The Ground Up. The tape includes a discussion of using PVC pipe as conduit. Is there a down side to installing, say two 1/2" PVC, conduits through the existing wing lightening holes in each wing? Clearly I need to clear the push rods but is there some other concern I've not considered?
Assuming PVC pipe doesn't pose a problem any suggestions as to mounting / anchoring them in place?
If PVC is a concern, would installing the conduit Vans sells be preferable if so what about the mounting?
