hcccs
After installing cylinders on my O-320 I noticed that some of the red pushrod tube O-rings protruded on one side. The machined holes in the cylinders give less support for the rings on the sides. It doesn't look good - the question is if I should remove the tube and install them anew. If there is a risk of oil leaks it needs to be done. Is there a risk or can I leave it as it is?
By hcccs, shot with DMC-FZ30 at 2009-10-11
![tubet.jpg](/proxy.php?image=http%3A%2F%2Fimg67.imageshack.us%2Fimg67%2F576%2Ftubet.jpg&hash=8045e7f29455e2ffa38338976bce8af6)
