JackinMichigan
The front push-pull elevator tube interferes with the flap control bracket.
I have a QB fuselage, so the mounting points for the stick controls and the first bell crank were pre-determined.
So far I have ground about 1/4" away from the bottom of the flap motor attach bracket which appears to just get the job done.
Anybody else encounter this problem?
Jack in Michigan
Jack in Michigan
