I'm at that stage where I'm designing my panel and am considering a push button start. I'd like to get your opinion because I am torn...let me explain.
1. If I were to use a simple push button start (keyless) then it would make it much easier for someone to steal the airplane. I've read enough here to know that the most likely scenario is that someone breaks in and steals the avionics.
2. If I go this route, I also have a safety concern. Last summer I watched some kids pulling on the propeller of a friends plane after he had stepped away to take a phone call. I immediately intervened! I realize the likelihood of a plane starting from a child turning the propeller is slim, but If I go with a push button start I'm there seems to be a greater risk to this happening.
3. If I were to hide a ground switch that had to be down in order for the push button start to be hot, then I feel like I'm introducing another way for this to fail when I might need it the most (inflight engine failure).
4. Perhaps there is a way to program the Vertical Power Pro so that the CB to the start button is always popped on powerup, meaning I would have to manually "reset" it on every start up?
Well, those are my thoughts and would love to get your input. Has anyone else went this route and what did you do?
