PTT switch source
N941WR
Legacy Member
Do any of you know where I can buy a small PTT switch similar to the one that comes with the teak stick grips?
I'm in the process of installing an autopilot in my -9 and would like to drill a hole in my teak grip and insert a PTT switch under my index finger to use as an autopilot disconnect.
Snap action
I should have known, McMaster-Carr has switches that look like will work.
Yes... but all little switches are not alike....:)
You need one here with a nice snap action, both in an electrical and mechanical sense.
Perhaps a visit to an electronics supply store in the nearest big city might be in order...
gil A
Southeastern Aircraft...
.....in Ft. Pierce, Fl. has both momentary on/off or push on-push-off that we use in the Air Tractors....they're very dependable and work for years.
Call Rick at 800 441 2964 and tell 'em I sent ya. It'll go out today if you call before lunch.
Regards,
