SmilingJack
So, it's been just over a year and I thought I had thoroughly checked out my "rear seat" stick PTT.
Found out from the pax the other day they could not transmit.
Now, comes the tough part, remembering how I wired this thing after a couple years. Yes, I have a wiring diagram, but now I have to figure out those fine details what, where and how I wired it.
Right now, the front seat headset works perfectly and if I reach back to the rear stick and key the mic I "also" am able to transmit using the front headset. But NO sound is transmitted from the rear headset. The end result is both PTT's transmit on the front headset mic and nothing on the rear headset mic.
I will say that ALL wires for both front and rear PTT are connected into the same terminal block. Is that ok? Or should I separate them?
Any thoughts?
Any thoughts?
