Radio is a Narco 120
PTT is wired out of radio, to switch, to firewall ground
Works perfect when master is on and engine not running, when engine is running and alternator field is off it works, when alternator is on then PTT/transmit doesn't work. Receives just fine. This is a new problem. Was working perfectly up until a week ago. Thanks for ideas, NORDO flights into towered fields, while good practice using light gun signals takes a bit of the fun out of the flight!
