LettersFromFlyoverCountry
I'm about done with the harness and such for the PS Engineering 1000II intercom (for those of you who've taken the SportAir workshop on avionics, it's the one for which you make a semi-harness.
I'm about to solder the wires onto the music input jack, but I've never seen this sort of jack before.
There are two wires in a shielded cable coming from the intercom, but I don't know where each is supposed to go on this configuration. There are three terminals.
The other question I have is on the wiring for the digital recorder in this model that replays the last received transmission. The instructions are pretty lame:
PM 1000II part number 11906 and 11908 have an internal recorder that stores incoming radio messages. A 3.5 mm jack is provided on the rear of the case. Install a momentary, normally open switch in a location convenient to the pilot. Wire to a 3.5 mm mono plug and insert into the jack.
So, here's my question. Huh?
Wire to a jack? Where to on a jack?
![music_input.jpg](/proxy.php?image=http%3A%2F%2F1.bp.blogspot.com%2F_nw6qmkwwuYE%2FS-2SHA6pqwI%2FAAAAAAAAC18%2FsSG7lnGwdxw%2Fs400%2Fmusic_input.jpg&hash=d54408a79870858ceb528aa1cd7d48aa)
