I have read a number of threads discussing throttle and mixture cables being damaged by heat. I have an idea that may help this problem. First has anyone tried this method and what were your results. Second I am not sure if this long a strip of copper can transfer enough heat to be effective. Feel free to give me your comments.
This applies to the cables used on an RV-8 IO-360-M1B. The OD for the cables is .350. The heat sleeve shown below is .5 ID and .020 thick. The plan is to wrap the cable one time with a sheet of copper with a thickness of 8 mil ( 32 gauge ). This would extend from the firewall forward over the complete cable to it's termination point. The heat shield would then be slid over the cable and copper with the exception of the last 8 to 10 inches before it reaches the firewall. The idea is for the heat absorbed by the cable under the engine to be transferred back to the firewall region of the cable where it is cooler. This sleeve material is available in many sizes and also as an open sleeve that is held closed with velcro. It is rated for 2000 degrees. A 3 foot section on Amazon was about $17. I have not purchased the copper yet.
![](/proxy.php?image=http%3A%2F%2Fi1347.photobucket.com%2Falbums%2Fp709%2Ftommyturner%2FIMG_2205_zpskmenwmv6.jpg&hash=6359d551414802fa89c2a85bb2fff5c0)
![](/proxy.php?image=http%3A%2F%2Fi1347.photobucket.com%2Falbums%2Fp709%2Ftommyturner%2Fa6605eac-ecee-4148-ab59-15348f3fad6d_zpszm4utvwl.jpg&hash=2b84f34a78295deb390fffc6e81761f6)
![](/proxy.php?image=http%3A%2F%2Fi1347.photobucket.com%2Falbums%2Fp709%2Ftommyturner%2FIMG_2206_zpso6smlmaj.jpg&hash=e4e2bed61ff6f685dfcfc8eecd514194)
