proper lubricant
bobnoffs
what is the proper lube for a steel pin that rotates in an aluminum hole?i have used whitegrease but it seems that a lube that could be put on the hole edge/shaft and be drawn into the moving surfaces would be more effective. i don't know that the grease is going anywhere.
3 of these make up the hinge for an aileron on my dakota hawk.
