I'm trying to determine the optimum cutout dimensions for the blades on the 2 bladed Hartzell blended airfoil prop as Vans sells, using the standard spinner kit. The instructions tell you to rotate the blades thru full travel to check for clearance, however I don't have an engine to mount the prop to yet, and it's not possible to move the blades without one. I am trying to get as tight of fit as is possible. I have looked at production airplane's installations, and they have a much larger clearance than I would consider aesthetic. Has anyone made a template or drawings that would provide the dimensions that I need?
